• This topic has 6 replies, 4 voices, and was last updated 8 years ago by dpfr.
Viewing 7 posts - 1 through 7 (of 7 total)
  • Tyre troubles?
  • dpfr
    In the last 3 months I have had two rear tyres fail in the same way. The sidewall rips just above the bead over a length of 8-10 cm, the tube bulges out and before I can stop, there’s a mighty bang. It’s not brutal misuse- I am one of the World’s great mincers.
    One was a Trail King which lasted over a year, and the other was a Nobby Nic which died today in asnowstorm after less than 3 months.
    Both have failed on the drive side so I am wondering if I am getting a bit of cleaner, or oil or something like that on them and it’s eating them? However, I treat the other mountain bike exactly the same way (Maxxis Ikon on that), and have had no troubles with that (so far!)
    Any advice from the collective mind, please?
    Shackleton
    Sharp edge on rim?
    dpfr
    Don’t think so. I had a good look at the rim this afternoon and ran my fingers carefully round it to check for damage. It seemed OK but I’ll have another look
    mattyfez
    What rims are they and what size are they? And what make /size tyre is on them..
    The obvious thing is the rim of multiple tyres are failing in the same way.
    mattyfez
    Also what pressure are you running, and what tubes?
    smatkins1
    As mentioned, sharp edge would be first thought.
    If the bead isn’t seated on the rim properly then I’ve heard of this happening where the edge of the rim cut’s the side wall.
    [90’s problem] You’re not using v-brakes are you and the pad’s catching the tyre [/90’s problem]
    dpfr
    Thanks All
    Rims = Hope Tech XC so 19.5 mm internal width
    Tyres which have failed = Trail King 2.25″ and Nobby Nic 2.25″
    Schwalbe tubes at about 40 psi
    Not using V-brakes! I’m pretty trad, but not that much
    Actually, thinking about it, the wheels are about 6 months old and I moved the Trail Kings on to them when I got the wheels, so they survived about 3 months on the new rims, and the Nobby Nics I replaced them with managed the same. I think I need to look very hard at the rim, don’t I?
The topic ‘Tyre troubles?’ is closed to new replies.
