I’ve never had a problem with tubes inside On-one Fatty tyres, on either On-one or Halo Tundra rims. Seem to fit easily, hence the posting about a problem now with the new Maxxis. The Minion is proving to be as good a front tyre as I could hope for in all other ways, grippy, rolls ok, controllable drift in the dry; also tends to stay in a straight line when floating across mud, which is a bonus.
I’ll try leaving it parked for a few days over-inflated and maybe ride it a couple of times at much more psi than normal, see if that helps. I’d like to get it down to 7-8psi to get the best benefit.
