http://www.demon-tweeks.co.uk/Product.do?method=view&n=1657&p=37314&c=215&utm_source=Google&utm_medium=Base&utm_campaign=Workshop%20Equipment&gclid=CIrD8IXMlMMCFaIIwwodtnUA1A
I have a cheaper version of that.
Makes the job a synch. – lay it down use the bead breaker , turn it over , do other side, spray some tire soap about the bead , put it on the spike , bolt it down ,hook the bead and pull the lever round the spike,
To fit…..tire soap new bead , force first one over into the well of the rim , should go with minimal levering.
Hook the top bead under the rim , use mole grips on the weight lip to stop it popping off , hook the other end of the tire lever between bead of tire and rim , pull it round the spike. Tire is on.
**** messing around with levers on the floor.
