Viewing 5 posts - 1 through 5 (of 5 total)
  • twisted shimano chain, split and rejoin or new pins?
  • AndyPaice
    rear mech went into the spokes on saturday and blew mech apart and twisted chain in two or three places. it’s only a deore chain and is less than 0.75% worn, so I recon a new chain will work on the cassette.
    Is it worth splitting the chain to remove/replace the twisted links and rejoining with the same pins (I have enough links but only one fancy shimano joining pin), add two or three powerlinks or just get a new chain?
    devs
    New chain. If you must use the old one use powerlinks. Original pins will last 5 mins if you are lucky. 3 powerlinks must be about the price of a Deore chain nearly?
    Steve-Austin
    Replace the whole thing.
    theotherjonv
    replace it – with a sram one and get a free powerlink?
    Otherwise, would you trust your nuts to your repair job next time you’re really cranking uphill?
    Marge
    stick it in the bin 🙁
    I had this happen on a brand new Dura-ace chain, due to my impatient gear shifting whilst trying to chase a mate down…
The topic ‘twisted shimano chain, split and rejoin or new pins?’ is closed to new replies.
