definitely south side, stop at teddington locks to session the dirtjumps
…and turn round as you would be going the wrong way.
Plus they need a little work (or did when I last had a look).
If leaving from Twickenham you are best riding through East Twickenham, over the bridge into Richmond and then picking up the path on that side of the river. Alternatively, if getting onto that side beforehand the next place up-river (ie against the direction you are going) is Teddington Lock.
Note that much of the path is gravel so not the best surface if your friend is on a road bike. It’s perfect Gnarmaccing territory.
