Alright guys, Just bought a sound bar for the bedroom and just trying to work out the best way to connect it all.
The sound bar has the following inputs, TV R/L, AUX, Optical and COAX, 1 of each with cables supplied.
I have a PS4 and a Virgin Tivo box, Both of which have Optical outputs but I only have the 1 optical input.
My TV Has a L/R output and SPDIF output.
Am I right in guessing SPDIF is high quality like Optical just different connections? If so, Can I use either a SPDIF to Optical cable or a splitter/adapter so I can run the TV to the Optical input so the sound from the PS4 and Virgin box will run to the TV then to the sound bar via the SPDIF – Optical.
Or would I be better off getting an Optical splitter/box to run the PS4 and Virgin box both to that splitter/box and then a single cable to my sound bar?
P.s if you’re looking for a cheap sound bar, you can’t go wrong with the Bush 150 watt Bluetooth one which is the one I have. Any help is appreciated, Cheers.
