The RF2 out on the Sky box also outputs 9V [if req] to power distribution amps – not sure if RF1 does, my memory is failing
RF2 outputs a voltage to drive things like a Magic Eye, but it’s disabled by default. RF1 does not, at all.
So is the signal so weak that the Sky box is boosting it so it works all over the house or is there something I’m missing?
Purely speculation, but it sounds like the Sky box is acting like a repeater. I’d no idea that it did that (and it’s frankly surprising if it does).
Are the connections on the cables good? Ie, are they mating in a manner which makes good connections on the box but shit ones with each other? I’ve seen some inordinately bad RF cable connections over the years.
