Viewing 4 posts - 1 through 4 (of 4 total)
  • Turner flux 09, will fox 120 work or is it designed for 100mm fork?
  • mudmonster
    On their web site the 2010 bikes have 120mm forks by the look of it.
    Ti29er
    Thought they were 100mm, mine is from 05.
    dickie
    The 2009 DW Flux is also recommended for 100-120mm forks – I run 120mm on mine & its perfect.
    chunkypaul
    owned a 2006 flux and used to run 85-115mm u-turn rebas on it
    it'll handle 120mm on the downs but if you do a lot of climbing you'll find it is better at 100-105mm travel
The topic ‘Turner flux 09, will fox 120 work or is it designed for 100mm fork?’ is closed to new replies.
