Viewing 10 posts - 1 through 10 (of 10 total)
  • Turner 5spot grease points
  • slightreturn
    I require a grease gun for my 5 spot. Are they readily available. And what type of grease is required.
    Thank you
    Stevet1
    I use manitou M prep grease (what Turner used to recommend), think you can get a grease gun to fit it as well.
    khani
    Here,
    You can get a Weldtight one with the same nozzle for a lot less but it’s not bent so you have to unbolt some bits to get on some of the ports,
    sam_underhill
    It’s a much easier job with the bent grease gun.
    I think Turner recommend a different grease now, but I’m still using M-Prep as that’s what I’ve got.
    renton
    Yep Turner recommend superlube now for the bushings etc.
    Onzadog
    M-prep works well in UK conditions but is very sticky.
    Superlube feels smoother but needs re-lubing more often.
    slightreturn
    How often are you adding grease ?
    Frankers
    I have spare grease guns and grease that I don’t use
    Onzadog
    You don’t purge the bushes when you grease them, you just top them up until you feel resistance on the grease gun. M-prep was probably about every ten rides, superlube is every other ride. I wasn’t adding much at all though. I do little and often.
    bennn
    Just out of interest, where are you all getting Superlube from, to fit the Turner grease gun?
    I can only find it in 85g tubes, isn’t that too small for the gun?
    Thanks, Ben.
The topic ‘Turner 5spot grease points’ is closed to new replies.
