Firstly ignore Strava power as its so inaccurate its not worth considering.
Secondly the average power output for an hour, unless you were at 100% effort the entire way, is also somewhat misleading.
If you’ve access to a WattBike then the best thing to do would be to perform a structured FTP test, something like the 2 * 8 minutes favoured by TrainerRoad.
From this you’ll get a much better figure to work with. You’ll also be able to use your HR values from the test to measure how hard you’re working on the road.
A power meter won’t make you faster, it will give you a load of numbers, you may get faster if you know what those numbers mean and what to do with them.
