I have:
* turbo (Elite Crono Fluid in this case), with my road bike plonked on it
* the Garmin sensors that counts rear wheel revolutions and cadence installed on the bike
* a computer (a tablet won’t do it) and the Zwift ‘ware
* a Garmin Ant+ dongle connected to the computer, to grab the data from the Garmin and stuff it into Swift.
plug it all together, it does work, it was straightforwards. HRM worked OK too.
work out how you are going to see your screen, if you are on a laptop you need some way to bring it closer than the end of your front wheel if you want any kind of ‘immersion’, or get a bigger screen.
I’m only 40km into Swift so it’s early days, yet to really get into the depth of it, I find I still lean on the dh corners with outside pedal down! I like the continuity of data, you push for a sprint PR on each lap/ride. Everyone seems faster than me, well the probably are, but I also assume the like-for-like comparison with people on different trainer setups has a significant margin of error. Like Strava, it’s a toy, don’t take the comparison with other riders too seriously. Against yourself, it’s valid I think.
I’ve done a few Sufferfests before, they’re effing relentless I definitely push myself harder, mostly because the cadence is usually set high and I find that hard (& you don’t need so much kit), but Zwift is more engaging as it grabs real data.
Zwift has legs, it’s only going to get better.
The feature I want is to see my ghost self from a previous lap to race against.
