And I’m sure he’ll hate it right up until he loves it or wants to sell it… Turns out 29ers do work, who knew that all that stuff about them not braking or pumping properly was gibberish? Everyone else, that’s who
This.
I’ve read every article and interview with CP going back over the past few years sharkattack, including that one.
Prolific tinkerer, geometry visionary and suspension genius he may be – but that doesn’t mean he doesn’t talk some pish at times.
If you want to smash g-out bikepark style turns then a 2.3 tyre at 30psi is probably just about the best tool for the job. What about roots and loose rock though? Tyre deformation is good. A proper wide rim means that rolling it off the rim is highly unlikely. Apparently CP likes a Crest rim to keep unsprung weight down though…
Surly DW tyres are the first plus tyre with a proper soft compound. They are ace, but I’ve put the NN’s on as the bike is going to Spain in a couple of weeks. Squidgy rubber is a bit overkill for the hot, gripp rock over there.
Haven’t tried 29er wheels papercut, today was my first outing on it.
I’ve no plans to build a 29er wheelset at the moment, I’ll probably borrow a set and give it a go sometime.
