- This topic has 84 replies, 20 voices, and was last updated 14 years ago by sadexpunk.
tubeless yellow rim tape
spooky_b329Full Member
I think for a full inflation its one per wheel, but I just use it to get the tyre sealed which happens almost instantly, then stop inflating and switch to a trackpump as I find I need 60PSI to get the beads to pop into place. You'd probably need two canisters per tyre to get enough pressure to get it to pop into place unless you use one of the extra large canisters.
AnthonyFree MemberI see from your other postings you often ride from Willingham Woods. I live 5 mins from Caenby Corner, If you bring some decent biscuits your welcome to pop round and I'll get them seated for you.
I'm certainly no expert but I haven't had any problems with either Flow's, 355's or Olympics.
sadexpunkFull Memberooh matey, ill take you up on that this week if i dont have any luck in the next day or so. when are you about at home?
fig rolls do you? 🙂
Fresh Goods Friday 696: The Middling Edition
Latest Singletrack VideosFresh Goods Friday 696: The Middlin...NorthwindFull MemberTrouble with garage compressors is that a lot are very low pressure (not sure why, maybe it's to stop people giving themselves aembolisms and suing?), same with small electric compressors.
My grandad had a homemade tyre fitting compressor which he used for car and motorbike tyres… Brilliant it was, he had an old jeep wheel and tyre which he'd inflate to about 60psi with a footpump, and a hose with a schrader fastener at both ends. One end on jeep tyre at high pressure, other end on car tyre, open valve, pop! One seated tyre. Hard work though. Basically a manual compressor. Me, I have a decent compressor, and I wouldn't like to do tubeless without it personally.
geordiepaulFree MemberI've got the 25mm tape in my Arch's and it went in fine (they're the same width as the 355's), just need to pull it really tight, smooth as a babies bottom!
My tyres sealed first time with a track pump….peice of cake, they weren't the tightest fit either. Both my Flows and Arch's done without one problem, my bonty's were a nightmare!
sadexpunkFull Memberright……ive had some success. not much, but some 🙂
ive cobbled together an adaptor and got it to work ok with the compressor at work. and its inflated the tyres 🙂
but……they came straight back down again, so must be pretty leaky. i could defo feel some coming out of the valve hole on the rim.
is this normal? i was sort of expecting them to stay up a little while, so that when i put sealant in, i can splosh it about while the tyres still inflated.
as it stands, if i put sealant in now, then id be rotating and shaking a flat tyre, which doesnt sound right :-/
if its relevant, i made the hole for the valve the same way as the youtube vids, with a little cross cut with a stanley, rather than a filed hole. should i stick another couple of bits of yellow tape over the hole and file a new hole you reckon?
NorthwindFull MemberI found mine leaked around the valve hole, but once the sealant was in and I gave them a shake that stopped. I've no idea if this is the best way to do it, but it worked- I inflated it once to seat the beads, then popped part of one bead off and added sealant. Then, inflated again to reseat the beads, and as the air escaped gave it a shake. The sealant soon found the holes, plugged the minor ones and sealed the stem and the beads. I did have to reinflate again and have a couple of cracks at sealing some bigger holes but it was easy enough. I had some suspicious white marks on the garage floor though! Very exciting this bike fettling
sadexpunkFull Memberexciting? you reckon? 🙂
i think for my own peice of mind im going to have to try again with the valve holes :-/
make em smaller than the valve with a round file, then push them through for a tight fit. then if thats no better ill press ahead and do as you suggest. keep inflating and swishing around til they hopefully stay up.SamFull MemberYou were lucky to get them up at all without sealant in there. Get the sealant in, blow them up, slosh it around. Blow them up some more and go for a ride for 10 mins. If they are stil lholding air when you get back you are good to go.
sadexpunkFull Membersurely the tyres would go up whether or not theres sealant in or not sam? its just that they go down again without it no?
so its ok to slosh the sealant around in a flat tyre?
is there any advantage in where the valve is when you inflate it? should it be at the top? bottom? or not matter?
will the sudden rush of air be trying to force the sealant out of the side of the now unseated beads once its gone down?ta
grummFree Membersurely the tyres would go up whether or not theres sealant in or not sam?
I had to put sealant in one of mine to get it to seal around the valve before it would inflate.
I put some sealant in and put the valve at the bottom so it would run down around it – seemed to work.
sadexpunkFull Memberthis was going to be by next question, before i get started.
im conscious that the valve is on the inside of the wheel. (good start eh?) and the sealant running along the bottom of the tyre. so in effect will never come into contact with the valve, and any little air leaks around it?
so i was thinking what a good idea itd be to have the valve at the bottom, then quick as a flash, invert it, so sealant could fill any holes around the valve. then i thought dur…… itd just fill the valve too and plug it all up wouldnt it???sadexpunkFull Membernope, i think ill answer my own question here. i really should think these things through properly before opening my mouth 🙂
air wont actually be coming out of the valve itself will it, so therefore wont clog up, itll just run back out. itll only seal the little air leaks around it. ho hum.
i reckon ill get this cracked tonight 🙂
another quick question about sealing it before too much air leaks. ive seen in the vids, the blokes shaking the wheel, tilting etc to get the sealant all over. and it seems quite slow to get round the wheel.
wouldnt it be quicker to hold the axle and spin it? and as its spinning keep tilting it from one side to the other?
id have thought the sealant would then cover the whole tyre quicker than the shake and tilt method?grummFree MemberMaybe yeah – I think you are thinking about this too much though!
The valves can get a bit claggy after a while but it's never been a problem for me so far.
AnthonyFree MemberI presume you are using a Stan's vavle?
I'll mail you my address just in case!
Anthony.
b17Free Memberdon't think you've said what tyres? try it with a real UST first?
sadexpunkFull Memberi havent got UST tyres,and dont want them to be honest. im hoping to not spend any more money on this project 🙂
i was hoping JRA might have sent me the correct tape for free, as i obviously struggle with the recommended 'wrong tape' they sent me, but thats a no-no so im going to just persevere with my sh*t effort 🙂oh, and ill put another layer of yellow tape over the valve hole, and do a neater hole with a round file this time i think.
ive got maxxis ardent up front, and schwalbe little albert on the back.
anthony, just read your mail thanks mate, and will reply to it in a sec, but im not sure if its a stans valve or not. its whatever JRA send out. presta, but im using a schraeder adaptor with it.
d-day should be on nights tonight. soapy water rinse, sealant in, inflate, cross fingers, curse, then kick f*ck out my tyres when it doesnt work 🙂
thanks 🙂
scaredypantsFull Membercan you remove the core from the valve? (I'd assume yes if it's from JRA)
I would do what you did but with the core out of the valve – soap the beads & inflate & seat the tyre without jizz in it. Get it pressured enough to pop onto the rim properly all round. If there's loads of leakage round the valve at this point, consider either tightening it a bit or maybe seal it better (got any bathroom masticy stuff ?)
Then when tyres well seated, remove the pump & let it deflate but hopefully stay on the rim. Inject jizz down the valve, put in the valve core & inflate. Then do the rotate/shake/swear at leaky sidewalls like they do on the vids.
sadexpunkFull Memberi was going to use the scoop as i know i need 2 of those. yes, the nozzle down the valve will be easier, but how would i know how much ive put in? guesswork?
cheers
scaredypantsFull MemberI use an old chain lube bottle with the hole enlarged a bit – you could just tip 2 scoops worth into that & squirt away !
sadexpunkFull MemberSUCCESS!! sort of 🙂
forgot to take my adjustable to work, and also didnt bring a syringe. so it was a case of either leave it another day, or press on with original plan of unseating bead and tipping sealant in. so i went for it. and its gone fine. after a fair bit of bubbling, it all settled down after id shaken it about, and theyre still up 🙂
one thing puzzling me tho. 1 tyre keeps springing a leak. its fine until i sit on it and ride, then it starts spraying out from a little hole. its not on the rim, its in the middle of the tread :-/
i position the tyre so the holes at the bottom and it stops. spin the wheel, fine. go for a ride, it does it again. i cant understand why its not sealing that hole. it even sprays sealant out each rev as im riding it.
itll also leak if i start pumping tyre up again. once the tyres were up, i checked pressure with track pump, and pumped up to 30psi. but sometimes as i pump, it seems to break the seal in this one place and sealant spurts out again.you reckon i need more sealant in there? i just dont understand why the sealant thats in there isnt plugging that 1 little hole.
scaredypantsFull Memberprob a bigger hole/split than you think – these are used tyres ?
you need jizz with bits in to seal bigger holes (see old threads on glitter etc 😯 ) or you need a "plug". tubeless repair kits tend to have strips of rubber that you fold & shove into the tyre using a little tool (suppose it's like making a proddy mat but I've never done either)
If it's a massive hole you might need to patch it from the inside
sadexpunkFull Memberscaredypants, ive just been to check and youre right 🙁 one of the knobbles on the tread is split (sorry, not a very clear pic but you should be able to make it out)
so my next question is………whats the best way of fixing it? im guessing the tyre isnt knackered just cos of this 1 knobble, so is it just a case of a patch on the inside of the tyre? clean it all up, patch it, then repeat the sealant process again?
or is there a quick fix where i can unseat part of the bead again, press a patch or something onto the inside of tyre, and away i go again?
pah! thought id cracked it as well 🙂
sadexpunkFull Memberbluddy hell this is becoming a work in progress int it!! and it wont stop til im happy and sorted 🙂
following advice, tonight im going to fix the inside of the tyre with a normal tube patch. which leads to another question. or 2 :-/
1. im going to hang wheel, break bead seal one side, fix tyre with repair kit, re-seal again and inflate. now will the tyre be all gunked up with solid sealant when i take the bead off? do i need to clean it all with soapy water again? or is it better to leave whats already there in place?
2. if i put the patch on, ill leave it an hour or so before inflating again to make sure its dried. and then probably put another scoop of sealant in. will the sealant thats already in there be ok left in the open air for an hour? or does it start solidifying? i assume that i still want to be covering the excess glue with grated chalk? it wont affect the sealant in any way?
thanks
b17Free Memberfor both points, the sealant shouldn't go off.
there's air in the tyre, so exposure to air with the bead off isn't any different.
I recently had to put 2 patches inside a UST tyre where a really good wallop put two splits in the tyre. Worked fine. I suspect that patching a UST is more effective though as there is a better layer of rubber inside for the patch to vulcanise to.
sadexpunkFull Memberive got some park tools 'emergency tire boots' in my kit too.
im defo going to use a patch, but do you reckon theres owt to gain from using one of these over the top of it?
spooky_b329Full MemberNah tyre boots are for splits. Just clean it up thouroughly, and patch it.
sadexpunkFull Memberhahaha!! i AM the badger!!!
had one explode on me earlier 🙂 big bang and milk all over me. just pleased there were no cameras about 🙂
think it was a combination of plenty of soapy water on the rims, and not being able to measure the pressure. i guessed. i guessed too high 🙂
all cleaned up and fitted again now. altho im bobbing it just using track pump now up to 30psi 🙂
ill go for a ride tomorrow and hopefully the pressure will stay the same.
b17Free Memberjust to join in your fun – i successfully converted one of my wife's wheels yesterday.
cheapy electrical tape to seal the spoke holes, cut out valve from old inner tube taped in, used non-UST tyre and stans sealant.
it took a bit of fiddling to get tyre to seat around the cut out valve, but eventually the compressor did it's thing. I only really used soapy water after inflation to help check for leaks. The sealant has done its thing nicely.
For the next conversion I'm going to get a real tubeless valve to put in, as the cut out version gets in the way of the tyre too much.
sadexpunkFull Memberyou did a non tubeless rim and non tubeless tyre without rim strips or 'ghetto' tube?? nice one.
did you use presta or schraeder valve? not really sure why you would have trouble seating tyre around the valve, as the tyre will be up on the rim, not around the valve? unless youre saying you had a load of leccy tape in there holding the valve in too?
can you explain a bit more, cos now ive had success with my 29er, i want to do my 26" mtb now 🙂 but thats a totally non tubeless set up. i was thinking of going ghetto with that one.
b17Free Memberhi sadexpunk,
I used a presta valve from a bmx tube. Actually I first tried the cut open bmx tube method, but couldn't get the tyre on (seems that DT rim and bonty tyre are rather tight!).
I cut the valve out narrow enough to get in the rim. The problem seemed to be that the tyre wanted to stay in the center of the rim and the bead wouldn't settle next to the valve at first. Some fiddling and mild cursing got it in in the end.
I did two wraps of insulation tape with the valve trapped between the two.
The key really seemed to be the compressor (aldi small one) and once up, the sealant. It first sealed with a small amount of sealant because I ran out. I've since added more and at the same time got to see that the tape was well pushed into the spoke holes by the pressure, but with no splitting at this stage. No sign of losing pressure so far.
kinda666Free MemberJust put some Mudx's on olympic rims, just used electrical tape and some mavic ust valves, mudx's quite tight to get on rim, but went straight up with track pump!
sadexpunkFull Memberhmmm might be worth a try then. ive got mavic rims (few years old now) and kenda blue groove/nevegals.
you chaps using removable cores? or unseating bead and pouring in?
hopefully ill have enough sealant left. shame i wasted a wheel full with my big 'fail' moment 🙂
b17Free Membermy first lot of sealant went in before even the first inflation. had to release the bead for the top up.
I'd go for the optimistic and determined approach of putting the sealant in and 'knowing' that you'll make it work.
scaredypantsFull Membersadex, you want a removable core anyway – better airflow for seating the tyre on the rim in the 1st place, regardless of how you inseminate the wheel
kinda666Free MemberYeah removable valve cores are a must, i was lucky with the mudx's went up with the cores in, but used cinders last time and took the cores out and used compressor and an adapter for the valve! Volume is your friend!
sadexpunkFull Memberam i right in thinking tho that you only get removable cores in presta valves? and arent they smaller diameter than the car type?
so if you just have a valve rather than an inner tube, do you need an adaptor for old rims that have been using car type, because the hole in the rim is too large?
or is that b*ll*cks? 🙂
b17Free Memberthe proper tubeless valves in my UST wheels are prestas with removable cores
spooky_b329Full MemberAll Schreader valves have removeable cores, though you need a little tool to undo them. The cap on Slime bottles has a valve core remover.
Presta, most are removable but once undone you have to let them drop inside the tyre, and pinch the inner tube between fingers to keep hold of the core whilst adding sealant, then manoevure the core back into the valve and tighten back up.
The Stans ones are different and can be removed to the outside like Schreader. Be careful with them as I went to top up my tyres a while back, undid the knurled nut and instead of undoing just the nut, the core came out and fired across the dining room, and I'm left sitting there with my finger over the hole, trying to let the air out slowly without spraying Stans up the wall and over the carpet 🙂 Just needed nipping up with some pliers. Five minutes later I almost did the same with the front, though I realised what was happening before it fired across the room 🙂
The topic ‘tubeless yellow rim tape’ is closed to new replies.
