I think I had Cafe Latex in – it lasted 4 months and as far as I know did a great job.
I’ve just tried some stans – seems to have filled in some holes ok… but who knows how it’ll be being ridden.
I hope I don’t need to buy a new tyre. I patched it inside and out to be safe, but the outer patch has a little bubble in it, but it doesn’t offer any resistance when I prod it, or seem to want to get bigger. Can’t hear any air escaping, but I don’t have a big enough bucket to put it in to check with water/bubbles. I was too lazy to fill the bath.
Totally removed the tyre from the wheel ( to check it hadn’t been buckled ), E1700 rims are awesome – cheers mr pinnick! Not entirely convinced I’ve got the tyre properly seated on the rim/bead… there’s a slight wobble going on when it’s spinning…. not sure if that was there before, but just noticeable if you look closely. It’s not there if you just look at the rim on its own.
Airshot was a good buy, though. I’ll see how I get on then have another go if necessary.
