For slightly loose tyres ive started applying stans with an old paint brush on the tyre bead and rim tape, just fold the tyre back and wet both with some stans. It helps the tyre go up a whole lot easier than when its dry or even with soap suds, I think the stans stays ‘wet’ longer.
For very loose tyres I revert to rubber rim strips. Most tubeless compatible rims don’t have a deep centre rim well so if the tyre is very slack there its almost too slack anyway, so I want the extra security of the thick rim strip. For slightly slack a 2nd or 3rd strip of yellow tape is usually more than enough.
When its not going right first time and the swearing starts I keep thinking I should get an airshot, but id rather put the effort in making sure the setup is correct so i can get it seated anywhere.
