Hello all,
Last night I attempted to set my raceface wheels up tubeless.
I installed some superstar rim tape first, a little fiddly as didn’t stick as well as i’d thought it would. A little patience and stretching the tape good and tight seemed to work though. I overlapped it quite a bit as the first bit wasn’t as tight as I may have liked.
Cut a little slit with a knife and popped some valves in.
First tyre, a mavic crossmax charge. Soaped up the tire and went up with no issues – easy! It appears to be leaking quite badly from the valve. Is the valve not tight enough? it’s just finger tight. Or will it be fine once I add the sealant? (this was a dry run to seat the tyre). Or is it something else?
Next tyre – brand new continental trail king protection. Tried adding loads of soapy water, bouncing the tyre, putting a tube in first and generally pumping like mad while swearing, no joy – I just can’t get the bead to seat? Any ideas? I really don’t want to use a compressor.
I’ve currently got both up with tubes at a good pressure and left them sitting there since last night. Thoughts being that it might ‘break’ the continental in. And also might help stick the tape better.
Any help appreciated.
