All,
Been running tubeless for a little while and while out on the Monkey trail got a puncture. The hole looked bigger than a thorn and you could hear the air and see some fluid coming out.
The Stans fluid didn’t seal it immediately but after several stops to keep topping up with air it seems to have sealed.
My question is ‘How good is the seal likely to be? Should I remove the tyre and patch it?’
Not that keen on risking a long ride and having the seal fail especially as the tyre is a very tight fit and I don’t fancy having to try and fit a tube on the trail. I guess the safe option is to patch but it’s going to be a messy job that I’d like to avoid if possible
Anyone got any similar experiences thoughts?
