The tyre pressure you run will be a factor of
1. Your weight
2. Tyre width
3. Rim width
4. Tyre/rim combo (some tyres are tighter than others).
5. How hard out you ride. If you never push your tyres very hard then they are never going to burp.
Without all of the above info your “what pressure” question does not tell us much…
I run 27 psi in my 2.35 Specialized Eskar 2Bliss controls mounted on DT 5.1 rims with the DT tubeless conversion kit. I only weigh about 70kg (11 stone) and push my tyres pretty hard on my 5-Spot.
Oh, and I have found you can go a lot lower in pressure with real UST tyres and UST rims. Conversion kits and non-UST tyres run with goo are much easier to burp!!
