Ghetto tubeless attempt going alright here:
Bmx innertube cut (schwalbe 20 x 1.5-2.5 Schrader)
tyre onto the rim fine (2.1 crossmark folding with exo protection on a well used xm719)
valve core taken out fine
used the pop bottle compressor idea – works AMAZINGLY. brilliant stuff.
Had tyre up at 60psi sealed as well as you can with no sealant.
problem comes with the whole idea of putting the valve core back in and trying to use the pop bottle compressor to fill ‘er up. I want to make sure it’ll go up before I stick the sealant in.
Topeak joe blow floor pump not doing enough on its own and the cheapo compressor just doesn’t push the valve in so no air actually gets into the tyre.
What other options do I have apart from borrowing a proper compressor that’ll inject air steadily rather than the instant 60psi of the pop bottle?
