You need to find out where the air is coming from. Stuff I have seen are: valve stem to rim leak, spoke holes due to bad rim tape, bead to rim due to damaged rim and or bead. I have not tried tubeless with Conti’s but I have had issues with very porous Panaracers.
Check that the bead and rim is clean and undamaged and soap it up when you fit it. I use a wall paper pasting tray(prepasted paper) to check for leaks, big enough to get a good section of rim and tyre under water and not needing too much water to do.
I would be wary of using white spirit to clean the inside as white spirit tends to leave and oily residue IME. Meths or IPA would be better I reckon.
