I’ve got the set up above, plus a Notubes kit, with rim strips etc. I realise I dont need the rim strip, though I will need a pair of valves instead.
But, will I need the yellow tape?
I installed the tyres with tubes yesterday and they seem to fit perfectly into the rims, I reckon I can seat them without the usual soap and water. Will the Hope rim tape do the same job as the Stans tape in that case, or do I need to either replace it, or fit the Stans tape over the top?
Or, should I use the Stans Rim Strips anyway (leaving the Hope tape on), to save buying separate valves? I guess the only disadvantage is a little extra weight, assuming I can still get the tyres to seat with the Stans Strip in there? It would make it easy to change damaged spokes.
