Are they the 2Bliss version?
Have you cleaned all the crud off the rim from your previous tyres?
I tubelessed the same rims on my Stumpjumper with the original Purgatory & Captain tyres, using just electrical tape on the rim. The tyres sealed really easily with just a track pump, but had been used with tubes for about 4/5 months prior to this.
I reckon getting the tyre to shape as you’ve done will help. I find when getting the tyre to seal with a track pump, it helps to push the tread towards the valve slightly where the valve sits to flare the bead out and get it to sit against the rim.
It does take a vigorous bout of track pump action, but no more than perhaps 10 strokes before it’s seated well enough to have a breather.
