My experiences… This was a little over 2 years ago and I have now bought a compressor to make it easier and save £ on gas cartridges. I also now use the Kuroshiro rims which don’t require rim tape, just sealant. The long term verdict on the method below was that it was perfect. Would recommend leaving the tube in overnight to squash the tape down thoroughly. Getting the tyres off is quite hard, and on the Kuroshiros it feels like the rim might just bend… You have to really pull the bead off the bead hook.
Decided to go tubeless on the fat bike tonight. I’d squirted some sealant in the tubes in the mean time, but as the tubes are so enormous the weight was considerable. Before I started the weight was 29.7lbs on the scales.
I used 3 layers of gorilla tape on each wheel, then refitted the tube, inflated to 25psi to seat the beads, then very very carefully let all the air out, removed the tube keeping one bead seated (this took a couple of tries), the fitted the valve and 150ml of tubeless spooge (Nuts! I usually use 50ml). The technique which seemed to work best was to lay the wheel down with the loose bead facing down to force the tyre into the well of the rim under its own weight.
Hanging the wheel like you do with a normal bike just didn’t work as the tyres are so heavy they pull down and open up a big gap between the rim and the tyre.
I then used a gas canister to get it seated and finished off with a track pump. Seems to be holding air fine, was a little weird when I rode it round the road as the bead seemed to be leaking air under load – never had this before with tubeless so will leave it to seal overnight and see what happens.
The weight was 27.9lbs on the same scales when I’d finished – happy days! It is really noticeable on the fat bike as that’s 1.8lbs off the wheel weight.
