I’m getting a new “best” set of cross wheels (which I’ll also use on the road in the summer), and was thinking about going tubeless, at least for ‘cross, probably not for road.
What rims and tyres are available? are there any specific tubeless cross tyres? or are most people running ghetto styley?
Are the tubeless rims all going to be 29er rims? and therefore quite a bit wider?
I’ve read a bit that says the wider rim is much better for cross as you get a much better cross section, and therefor less “balloon” effect which then gives a bigger contact patch and reduces pinch flats, but if I then use the same wheelset for road in the summer, will the rims be stupidly heavy / fat and give a weird profile with 23mm / 25mm road tyres?
Anyone got any recomendations for setups? I’m thinking DT Swiss 240 hubs, and was thinking of Mavic CXP33’s, but if there is a specific tubless rim that doesnt give any disadvantage, then I think its worth trying.
