Right, I’m in the middle of my first tubeless conversion
Mavic 319 with Nobby Nic (Tubeless ready).
Rim taped, valve in.
Tried to seat tyre with track pump – pointless, nothing doing.
Next step, remove valve core and inflate using one of those little CO2 canisters. First time success (feeling pretty smug at this point!).
However tyre did not remain seated when the canister was removed. No matter I’m thinking I can easily re-inflate (I’ve 5 more CO2 jobbies). So pour in sealant, shake rattle and roll etc.
Try re-infalting with CO2 – no joy, lots of CO2 escaping and presumably some latex (4 canisters left)
Try again – no (3)
Again – no (2)
Again – no (1)
Last canister and it inflates. Hurrah!!
Pop valve core back and pump with track pump to about 40psi
Shake, rattle and roll.
That was about an hour ago.
The tyre is still inflated but it is leaking slowly
Should I re-inflate to 40 psi again? Or just leave overnight?
If the latter, assuming it’s flat in the morning, is it likely to inflate and seat easily (with a pump).
Realise these things are always ‘well it depends’ but appreciate any pearls of wisdom.
Al
