will be attempting to get my 29er stans crest (i think) rims sorted in the next week or so. done stans before, and also converted some old mavics ‘ghetto tubeless’, but it was that long ago i cant remember it all. think i used the ‘9p pop bottle’ trick for inflating so will have to dig that out.
ive got some kenda nevegals ready to go on, and am reliably informed i dont need the rim strips, just the yellow tape and a couple of valves with removable cores.
as ever, im trying to save money (it always ends in pain :-), and have seen some people say theyve used gorilla tape. just wondered if any of you use it. the yellow tape id need would be 25mm, and handily, gorilla tape also comes in inch wide flavour too, for about £3.50. and im sure if i could be bothered with the faff of cutting it to size, the bigger rolls would be even better value, but i think the 1″ size is the right compromise.
also, i know the schwalbe inner tubes have removable cores. worth buying a couple of those over the ‘proper’ ones? in fact is it possible theyd be better, as you could cut a larger section of inner tube out? would that help seal them?
thoughts please.
thanks
