Okay, next question! With all the fancy modern and shiny bits on my new bike I decided to take the plunge and go tubeless last night (ooerr matron!), but failed miserably. I’m trying to fit Joe’s Eco tubeless system to Alex Volar 2.5 tubeless ready system rims fitted with a Maxxis High Roller 2, Minion DHF combo of tyres. I cleaned the rim and removed the spoke tape that the shop mechanic had put on while wearing boxing gloves (only explanation I can think of for missing so many spoke holes), and fitted the supplied yellow tape over the spokes. I then fitted the tubeless rim belt, which for all the world looks like the bottom half of an inner tube with the valve still attached. This went on easy enough with the belt running up the rim, over the plastic bead and into the slot that the ridge of the tubeless ready tyre fits into. All fine so far and I hadn’t even used a sweary word. Now the instructions told me to fit one side of the tyre onto the bead (I’m assuming that’s into the bead, on top of the rubber rim belt to make an airtight seal, right?). Now, note I said ‘told me’, didn’t show me how, just told me to fit one side of the tyre to the wheels bead. Is it a magic spell? Do I need three extra hands? Apart from anything, the few times I had even partial success (by running a tyre lever under the tyre and pulling it onto the bead, the tyre still wasn’t seating properly into the rim. Although that might change as it was put under more tension, but I never got that far as it kept popping back off. So, do I have the right tubeless system for my wheels and rim combo? The rims are 25mm internally, and I think the kit said it’d fit 21-24mm rims in 27.5″ guise, but I’m pretty sure the sizing is correct anyway. I know that everyone says blast it with high pressure air, but surely there has to be some sort of seal for that, and it just wasn’t happening last night. Is there a trick to getting the tyre onto the bead? Better yet, is there anyone who’d like a nice bottle of wine in exchange for coming over and showing me how to fit the damn things? :-p
Beagy x
