- This topic has 49 replies, 22 voices, and was last updated 8 years ago by tomd.
TRP Spyre failed, very dangerous
tehtehtehtehFree Member
so I braked with very worn down front pads earlier, and had a total failure of the brake. this is definitely a post recall model, but I think it is failing in the same way the earlier brakes were – as I was putting pressure on the lever they just went ping and I lost braking force, I thought the cable had snapped at first but upon checking it was the caliper, I can wiggle the actuator and get everything to ping back into place but there is absolutely nothing I can do from the brake lever itself
needless to say, if this had happened at a more critical time I would have been hurt
I also took checked the back, the pads were not so worn so I just took the wheel out to see what would happen without the rotor in there to resist…. same result basically
don’t think I can ever trust these brakes again now
amediasFree MemberDoesn’t sound good, glad you are OK!
define ‘very worn’
ie: past when they should have been replaced, or just close to when they should have been replaced?
RorschachFree Memberdon’t think I can ever trust these brakes again now
Or you can replace your pads before they’re knackered.
.I also took checked the back, the pads were not so worn so I just took the wheel out to see what would happen without the rotor in there to resist…. same result basically
A brake that does’nt work without a disc in….well I never.
amediasFree MemberI was trying to be diplomatic in my post 😛
Clearly you should replace the pads before they are worn out, but they also shouldn’t really fail in a catastrophic manner if the pads are just ‘very worn’ rather than gone.
A decent brake should* still allow the pistons sufficient movement to apply pressure to the rotor even with the friction material gone and you’re just rubbing a back plate against a disc.
*in my opinion
tehtehtehtehFree Memberdefine ‘very worn’
about a 1mm of pad material left on each side, maybe a little less, but not worn completely through, certainly in the ballpark for replacement
listen to what I’m saying clever clogs, that’s just what I did to check the back to see if did the same thing, the front did this with the rotor in place
I thought the whole point of the recall was that this was an error and it should have been fixed
STATOFree MemberI was putting pressure on the lever they just went ping and I lost braking force
As in, apply even pressure, then suddenly the actuator/piston jumps to its stop? or Ping its finally bottomed out after slow pressure?
Thats different to a ‘ping’ and all power lost.
I thought these brakes auto adjusted for pad wear? are you saying they dont have enough?
TBH, its not clear, but sounds more like a gradual progression to no brakes, not sudden failure. Needs clarification.
tehtehtehtehFree MemberI was trying to be diplomatic in my post
*in my opinion exactly right
ransosFree MemberI thought these brakes auto adjusted for pad wear? are you saying they dont have enough?
No, they have 3mm allen key slots either side to wind the pads in.
JAGFull MemberA decent brake should* still allow the pistons sufficient movement to apply pressure to the rotor even with the friction material gone and you’re just rubbing a back plate against a disc
You’ll be pleased to know that car brakes are designed so that the pistons don’t pop out or the pads fall out of the caliper when both pads are worn down to the backplate (no friction material left) and the disc is 1mm below minimum thickness.
I hope my bike brakes are similarly designed 😯
STATOFree MemberNo, they have 3mm allen key slots either side to wind the pads in.
Ah ok, getting confused with the hydro ones. fogot the spyre are mechanical.
RorschachFree MemberFrom the TRP manual
SAFETY CHECK
Before Every Ride:
· Spin Wheel to be sure rotor is undamaged and aligned
· Check brake pad thickness, if pads are less than 0.8mm replaceSAFETY WARNINGS & INFORMATION
WARNING – Pad thickness must be at least 0.8 mm. Confirm this before each ride.tehtehtehtehFree MemberAs in, apply even pressure, then suddenly the actuator/piston jumps to its stop? or Ping its finally bottomed out after slow pressure?
TBH, its not clear, but sounds more like a gradual progression to no brakes, not sudden failure. Needs clarification. ok I will try to describe in more detail… but basically it’s very sudden
braking hard, ping and all force is gone, the actuator arm jumps back about half way and jams there, if I wiggle the actuator arm up and down I can get it to ping back, but I can’t do this from the lever alone, also the actuator arm jumping back while I’m pressing the lever forces the cable out of its stop at the lever, which further complicates things
they don’t auto adjust btw, but I keep them well adjusted myself
amediasFree MemberCheck brake pad thickness, if pads are less than 0.8mm replace
Pad thickness or friction material? I’m assuming friction material as otherwise that’s a very thin backplate!
Sounds like OP’s pads might have been at or below this limit, or wore down below it during the ride, so should have been replaced, but I still stand by my comment that a decently designed brake should allow for this and not fail in catastrophic manner if the pads wear out.
Pads wearing out or an end user forgetting to replace them is not an un-expected scenario to design for, reduced effectiveness due to running out of friction material is one thing, but a brake that can’t even apply pressure to the disc once past a certain wear point (not even on the backing plate) is not good.
tehtehtehtehFree MemberFrom the TRP manual
SAFETY CHECK
Before Every Ride:
· Check brake pad thickness, if pads are less than 0.8mm replaceI have the manual right here in my hand and nowhere does it say that
what it does say is:
Pad thickness must be 0.8mm. Confirm this before each ride.
what it does not say is that if you ride on ok pads and they wear to a little bit less than 1mm during the ride these brakes could kill you
tehtehtehtehFree MemberPad thickness or friction material? I’m assuming friction material as otherwise that’s a very thin backplate!
Pads wearing out or an end user forgetting to replace them is not an un-expected scenario to design for, reduced effectiveness due to running out of friction material is one thing, but a brake that can’t even apply pressure to the disc once past a certain wear point (not even on the backing plate) is not good.yeah you get it
simply put, I’m pretty competent with my bike maintenance and this has happened to me, so I definitely don’t think these are safe enough for all the stupid people that might be using them
davidtaylforthFree MemberCheers for the heads up; I’ve just got some so I’ll remember to keep an eye on the pads. Have you emailed TRP about it?
tehtehtehtehFree Memberyes waiting for a reply
I’m dreading the standard ‘send them back to us and make do without your bike for the next few weeks’ response
tehtehtehtehFree MemberRorschach feel free to keep riding them, I’m sure you’ll be fine
legendFree MemberPad thickness must be 0.8mm.
Kinda sounds like it does
tehtehtehtehFree Memberyou’re all entitled to your opinions of course, but I think a brake that totally fails if you step a fraction outside of the operating parameters is not a good idea, especially knowing how pads can significantly wear during the course of one ride
wwaswasFull Memberare the rotors within tolerance?
I can imagine a ‘thin’ rotor plus worn pads is going to increase the chances of there being a problem?
amediasFree MemberIndeed, and even if it is acceptable (I think not) then the heads up as to how severe it is on this particular model (compared to other brakes which do not fail in the same way) is appreciated.
HoratioHufnagelFree Memberyou’re all entitled to your opinions of course, but I think a brake that totally fails if you step a fraction outside of the operating parameters is not a good idea, especially knowing how pads can significantly wear during the course of one ride
+1
can’t believe people find this acceptable.
tehtehtehtehFree Memberare the rotors within tolerance?
I can imagine a ‘thin’ rotor plus worn pads is going to increase the chances of there being a problem? they are sram centerline, so not the ones that came with the brake but still almost new – a check with the calipers says they’re the same width as the stock ones, so they should be fine
brassneckFull Memberyou’re all entitled to your opinions of course, but I think a brake that totally fails if you step a fraction outside of the operating parameters is not a good idea, especially knowing how pads can significantly wear during the course of one ride
It isn’t of course, but it does rather depend on whether it’s only happening to your brakes or if it can be reproduced on others.
nemesisFree MemberI ran my front Spyre pad down to around .5mm of braking material left before changing them recently with no issues.
That said, they shouldn’t fail as the OP has described unless it’s a manufacturing fault or something else is different.
OP – what has actually ‘pinged out’? has the thread run off the track so that you’ve effectively unscrewed the piston by driving it too far (due to pads being worn)?
Just remembered – someone on here (Rocketdog?) had a similar issue with Tektro Lyra brakes a while back IIRC. And found someone else with the same sort of issue as the OP here: https://yacf.co.uk/forum/index.php?topic=50316.0
tehtehtehtehFree Memberalso thinking about it since I had the measuring calipers out, if I saw a pad with 0.8mm left I would think there was loads of life left in it, it really is much more than you expect it to be
nemesisFree MemberIf that’s the issue then you can stop it happening by taking up the slack with the adjusters on the caliper (NOT the cable adjuster on the caliper but the 3mm allen key ones on either side) rather than with the brake cable.
tehtehtehtehFree MemberIt isn’t of course, but it does rather depend on whether it’s only happening to your brakes or if it can be reproduced on others.
yes good point, I’ll keep the thread updated if/when I find out more
cloudnineFree MemberReminds me.. I need some new pads for my spyres… Any good deals / recommendations?
tehtehtehtehFree MemberI ran my front Spyre pad down to around .5mm of braking material left before changing them recently with no issues.
hmm ok thanks for letting me know, could just be a fault with mine, but both my brakes are doing it which is a bit of a coincidenceOP – what has actually ‘pinged out’? has the thread run off the track so that you’ve effectively unscrewed the piston by driving it too far (due to pads being worn)?
Just remembered – someone on here (Rocketdog?) had a similar issue with Tektro Lyra brakes a while back IIRC. And found someone else with the same sort of issue as the OP here: https://yacf.co.uk/forum/index.php?topic=50316.0 thanks for showing me that, it sounds rather similar, but from 2011 crikey!
http://singletrackworld.com/forum/topic/psa-trp-spyre-rebuild-guide
this is a thread showing the internals of the spyre, I think it’s the pre recall model but should be similar enough, there are ball bearings inside little ramps and as the arm rotates they roll up the ramps which pushes out the piston, if the arm rotates too far the balls come out of the ramps, that was what causes the recall in the first place, I don’t know if it’s doing something similar with mine but the descriptions sound like it
I found a thread from the guy who says he triggered the recall in the first place and his description also sounded similar to what happened to me
leffeboyFull Memberif the arm over rotates the balls come out of the ramps
I had this on pre-recall spyres and what happens is that the balls drop into the next ‘hole’ which means that the brakes just pull out again. It’s very scary when it happens on both at once 🙁
What I found then is that the brakes had to either be slightly off center or have the adjuster wound all the way out. It might be worth checking if you have either of these conditions as well. Without it the brakes would pull on but wouldn’t get all the way round to drop into the next hole on the ramp
tehtehtehtehFree Memberwell what’s scary is that it’s still doing it, this is what they said at the time of the recall:
We have discovered that in a specific scenario, the balls can be forced from the ramps if the actuator arm is fully activated to its stop with excessively worn or no pads installed.
and that’s exactly what is happening now, leading me to think it hasn’t been fixed at all? why don’t they actually move the stop so the arm can never rotate that far in the first place?
thanks for all the responses people, I will keep the thread updated when I find out more
tehtehtehtehFree MemberI bought them maybe 6 months after the recall and they have the hex pad adjusters on both side, and the little “3mm pad in” arrow sticker, also asked the shop if they were post recall and they said they were
dunno what more I could do to be sure, unless somehow those ‘pad in’ stickers were put on a pre recall caliper then I’m pretty sure it’s post recall
ahwilesFree Memberanything new to report?
spyres are on my list, but this thread has raised an eyebrow or 2.
scaredypantsFull Memberhaven’t seen this thread before
what’s new to report is that I’m oot – that’s some scary shit and I am NOT the sort of rider who checks pads anywhere near often enough to negate that risk
The topic ‘TRP Spyre failed, very dangerous’ is closed to new replies.
