My current Whyte Saxon CX bike has had BB7’s, HyRd’s and is currently on Shimano R685’s and I can’t see that changing any time soon.
The BB7’s worked, felt a bit wooden and needed adjusting to compensate for pad wear.
The HyRd’s had a nice feel plenty of power and good modulation, but no matter how well you set them up when the lever comes back to the bars the pads are only half worn. Adjusting the cable is no use as that just stops the caliper lever from returning and allowing more fluid through to the pistons, the only cure is to top the caliper fluid up.
The Shimano’s are excellent, great feel and power. When the levers touch the bars the pads are worn out, stick new ones in and you’re away again.
The only problem I’ve had with them is the god awful noise made by the Metal Shimano pads, the original Resin pads were fine and lasted a reasonable amount of time, the Metal’s haven’t lasted much longer but the noise is horrendous. I won’t be buying those again.
