Use the gear calculator to get your answer.
You should always be able to match a conventional triple granny gear to the same gear on a double. The question is if you lose any range in trying to keep the same granny gear when running the double.
To give an example, the standard triple granny gear is 22T chainring with a 32T sprocket. You could match this granny gear even with XX1 (42T biggest sprocket) by running a 28T chainring. You’ll lose out though in top end speed. It is up to you if it bothers you or not. If you are only worried about the granny gear then a double will be more than fine, or even 1x is possible.
