Viewing 22 posts - 1 through 22 (of 22 total)
  • Tringle Speed
  • mikeyd
    Building up a singlespeed using an old mech as the tensioner, then I thought I might as well add a couple more cogs..
    That seemed to work quite well… so I thought it would be nice to be able to change those 3 gears…
    Seems to work well – all the way forward on the fork lockout is 21:39,all the way back is 11:39 and is 16:39 is somewhere in the middle.
    phutphutend
    This is something I’ve thought about for a long time. Bit like an old Sturmey Archer but durable. Gears for up, down and along.
    cynic-al
    Why do people do this?
    wwaswas
    Good to see a well stocked garage 🙂
    cynic-al
    I mean singlespeed or normal gears, Shirley?
    mikeyd
    because:
    Weight increase is neglible due to the super lightweight shifter.
    And don’t call me Shirley.
    scotroutes
    Or just use a triple crank and SS hub?
    mikeyd
    I did think about that as well, although you would still need a tensioning device at the back which would add weight.
    This was just from stuff in the spares box.
    jameso
    I’m with Al, if you have a mech, why not have more gears? The weight argument is there but it’s not a very strong one. I only have 6 gears at times but that’s a Hope SS hub so there’s a reason for it. Until the hub bursts into flames I guess..
    But I’m impressed by the use of the remote lever to shift gears, that in itself deserves a Useful Bodge Award. And I guess it lets you keep the chain tension / mech position tight.
    On a similar line, I borrowed a surly tensioner with the adjustable jockey wheel position to try a 3-spd manual shift. Daft, but the idea was to have a SS-ish remote touring bike with a choice of ratios. The tensioner adjustment should allow the chainline offset to work with less risk of dropped chains. Decided that a thumbie and mech with 3 more cogs was weight I could live with …
    thepodge
    I like that, wondered about doing something similar for my town bike using a thumb shifter on friction as its flat all the way to town other than one massive hill I have to walk up, would make carrying the shopping back a bit easier too
    velocipede
    Shirley, you need a 32 or 34 to give you a mire useable range off road? You could also then get the ring on the inside of the spider for (possibly) a better chainline?
    Like the idea though – I’ve done the triple ring, single cog before and it worked a treat…
    mikeyd
    Yeah, the 39T unramped chainrings were £7 on CRC, I would have preferred a 36T.
    I may have to change the cogs (11 – 18 – 24 maybe) on the back to suit my riding when I’ve tried it off road.
    Chainline seems ok due to the cogs being shifted to the end.
    endurogangster
    Wouldn’t a tringle speed have 3 cogs at the back and 3 at the front that all use the same length chain like a dinglespeed? What you have there is just a bike with 3 gears!
    ontor
    if you’re doing all that you might as well add 5/6 more…
    mikeyd
    True, I suppose it is just a bike with 3 gears
    cynic-al
    You save say a hundred grams?
    birney29
    Got to admire someone who can look at something perfectly functional, like a geared bike and thinks to themselves “how can I make a totally shit version of that”
    And then they go and do it.
    pipiom
    Mud X’s mmmmm like em!!
    mikeyd
    lol, yep pretty much. I’d be pretty miffed if I started out with a geared bike too!
    XT cassette = 300g, 3 small cogs = 50g? (250g saving)
    XT 9spd Shifter = 125g, fork lockout = 25g? (100g saving)
    350g saving being optimistic? 300g saving being Cynical?
    75g penalty over pure SS?
    jordie
    What car does the front wing fit?
    mikeyd
    Audi A6 C5 – It’s for sale if you want it…
    velocipede
    All the cynics above should get a job with the UCI!
    ;o)
The topic ‘Tringle Speed’ is closed to new replies.
