Hi ,
I have recently changed my chainset to a 9 speed (22/32/44 tooth combo) from an 8 speed (22/32/42) but left all of the other transmission unchanged from 8 speed. The problem i have is that the chain seems to be very slack on the smallest chainring and rubs against the bottom of the front derailleur cage.
I had already adjusted the height of the front derailleur so as to leave a 2mm gap between the cage and chainring tooth.
Will i need to adjust the spring tension of the rear derailleur to take up any slack in the chain when on the small chainring or will i need to take some links out of the chain?
Thanks
Phil
