I’ve had mine for 8 months it was a 2015 version so came with no volume spacers in the can and I really struggled with it for the first month with very harsh bottom outs as you blow through the 125 travel on rough terrain. This was solved with 3 volume spacers. The the suspension is very active but also very efficient for the sort of bike it is, I pretty much leave my shock in descend mode 99.9% of the time despite running 35% sag.
It’s long at the front so is a bit of handful climbing but on the other hand that suspension linkage generates huge amounts of grip for technical climbing, however the low BB takes some getting used to and will cause issues on some terrain.
The bike works really well with 150 fork and because of the low BB I wouldn’t fit anything else. This bike is an absolute monster on flowy, twisty, smoother trails. It also loves to change lines and corner hard.
Where it isn’t is good is high speed stability on rough terrain that 425mm chainstay coupled with just 125mm travel means when it doesn’t give you that that planted, stable platform like you get on some other bikes with more travel and longer chainstays.
If it was me and I was riding a lot of Dark Peaks trails then I would get the patrol. I used to ride them more but since I got the the scout I don’t find it the best tools for smashing down those descents.
AT the moment I’m considering swapping out to the Patrol frame (5mm longer chainstay and 30mm more travel) or keeping the scout for what it’s good for and getting something like the GT Sanction or BMC Trailfox for the stuff it isn’t so good at.
(EDIT)
Forgot to mention massive plus of this frame! It is ridiculously stiff, so no flex when you slam it into a corner.
