Chew, there’s lots of gps tracks for the main route on the web. Here for example: http://es.wikiloc.com/wikiloc/view.do?id=1131414
I often see people doing the route and it’s funny the trails they are on, I think that they are following known walking routes and mixing it up with fireroads. You’ll cycle through some beautiful scenery and past some amazing trails! For example, you’ll pass the point we uplift to 1350m in the photo below. Instead of taking the 22km singletrack back to the valley you will cycle down the fireroad we use to uplift. It’s just what you need to do to make time and if that sounds like what you’re after then it will be an amazing route.
There’s also a company which does the route supported, I can’t remember but think that it’s pyracif. If you do it and are at a loose end when you hit the Atlantic, give’s a shout!
