- This topic has 3,507 replies, 51 voices, and was last updated 8 months ago by Duggan.
TrainerRoad – STW approved sessions
whitestoneFree Member
There’s a pretty big thread on the TR forums about it (the plan builder) https://forum.trainerroad.com/t/introducing-plan-builder/25201 that might be worth reading though it’s a mixture of bug reports and feature requests.
It looks like you need an ‘A’ race or event in your calendar for it to lead up to, just make one up if you don’t race. Seemingly it takes into account recently completed plans. Also the amount of base or build you end up with depends on what you select as your level of expertise.
Worth having a play with even if you don’t commit the plan to your calendar – you can review it before doing so.
tomlevellFull MemberA watt is a watt. I gained 4 after base 1 this time around. But then I’ve got myself upgraded to a B racer on Zwift a month earlier than last year from a lower FTP starting point and in theory still lower on FTP.
Had a fiddle with the custom builder and for me right now it doesn’t work as I started the plan to finish when I wanted it to with a couple of weeks wriggle room. Nearly completed base so I don’t want more base which is what it suggested to hit the goals coming up but then I’m counting an event in Feb as A but I’m not aiming to finish Specialty by then so really it’s a B event but not really.
Going forward from May I’ll give it a go and I’m still missing key calendar date anyway.whitestoneFree MemberWell this week’s workouts have been Ebbett on Wednesday and Kaweah today. Both felt easy. As in: today’s intervals of 10mins meant to be at just below FTP only had me slightly out of breath, in fact I did all five at 6W higher than the target meaning I was just over FTP.
I suspect I underperformed on Monday’s ramp test for whatever reason. Next up is Taylor-2 – 30 seconds VO2Max, 30 seconds rest … repeated 14 times! There’s three blocks of those. I’ll see if I think my FTP is too low after that.
13thfloormonkFull MemberSo I’ve not long come out of surgery for a herniated disc. Was training for CX season before the whole issue kicked off and was sitting at 3.4W/kg.
5 months total no riding so lord knows how much fitness I’ve lost.
How would I use Trainerroad to build a plan for next season e.g. 40 weeks away. Do I just build backwards from an 8 week Cyclocross plan? E.g. 8 weeks Cyclocross plan, preceded by 16 weeks build, preceded by 16 weeks base?
Is the base plan still based around an FTP, e.g. would I need to do a ramp test on day 1 to get the best of it?
whitestoneFree MemberThey (TR) have just introduced a Plan Builder which you use in conjunction with the Calendar. Enter your events in the Calendar then use the builder to work out the plan for you. There’s a big thread on the TR forums about it. The builder is a sort of “wizard” and works out your level of expertise – the plan for 40 weeks might go: base-build-base-build-speciality. It then populates your Calendar with the relevant workouts.
All plans are based on FTP so you’ll need to do some form of FTP test. The current recommendation is to do their ramp test but you can opt to do the 8min or 20min test if you think that suits you better. The ramp test is less stressful than the other two so if you need to retest then it’s no big deal to do so. You can also manually alter your FTP if you feel that’s the best way to do it.
13thfloormonkFull MemberDoes it offer Trainingpeaks style logging of time spent in zones etc?
barrykellettFree Memberwhitestone
Next up is Taylor-2 – 30 seconds VO2Max, 30 seconds rest … repeated 14 times! There’s three blocks of those. I’ll see if I think my FTP is too low after that.Taylor -2 is only 0.83 IF
It’s pretty easy in truth.whitestoneFree Member@barrykellett – that’s good to know 😊
@13thfloormonk – This is the workout I did today https://www.trainerroad.com/career/bobw/rides/68287868-kaweah (hopefully it’s visible) I’m on a wheel-on trainer so the power trace is a bit variable. Beneath the graph are a couple of tables showing power, cadence, etc. for each interval and overall time in each power zone. Not sure what TP shows as I’ve never used that program. I don’t have a HR monitor that works with my current setup so no data there but if it was it would appear as a red line on the image/graph.The couple of seconds spent in Anaerobic are just short blips in moving to the big ring when starting the main intervals. Also I shouldn’t have any time in VO2Max but that’s probably a consequence of my FTP being a bit low, my current thought is that it’s about 6-8W too low.
13thfloormonkFull MemberNice, I like data! 😎
Does it keep a log over time though, e.g. weekly total time in each zone etc?
That’s what trainingpeaks seemed most useful for, keeping a really detailed log over the days and weeks
whitestoneFree MemberNot sure about time in each zone over time, I’ve not looked for that. They do track TSS in the Calendar but I think that’s it. Just had a search on their forums and it doesn’t look like it does.
They (TR) do seem open to suggestions about new features but I suppose like every company they’ve got limited engineering resources and there’s only so many things. If it’s something that they think is useful/sellable/whatever then they’ll allocate time/resources to it. I suspect that they don’t want to simply replicate what other programs do.
steviousFull Member@13thfloormonk – I used to use TR and TP alongside each other, partially for the stats that you mention, but also the CTL graphs and a few other things. I had a bit of a subscription bonfire to save money and decided that enough of TP and TR overlapped to drop TP. Not only do I not miss the extra stats, but having less data helped me think a lot more clearly about how I train (which is useful because I have to fit it around a young family now). Now I don’t have to waste time looking at data that I’m not realistically going to do anything about (why do I need to know how long I’ve spent in ZOne 4 this week? I don’t).
13thfloormonkFull MemberCool, think I’ll just do ‘base’ without TR’s assistance, will just be easy winter road miles! Prob sign up April onwards with a ramp test to begin with.
I’m extra cautious now after too many injuries, was advised to build slowly e.g. 10% more per week, and obviously maintain 80/20 polarised split. Plus stats, I like stats.
tomlevellFull MemberI have TR invites available.
Gives you a free month then you can cancel.
Worth a go to see if it works for you.3 available if anyone wants one.
13thfloormonkFull MemberYes please Tom!
Will give me something to mess about with until I’m back on bike at least, then see if I want to sign up straight away or after doing my own base stuff.
Ta
teamslugFree MemberPalisade for me today. Kept to power and felt ok til last set when I was blowing. Struggled to get cadence back up to a level that seems to make things a bit easier. Last week of SSB1 ( recovery week) to do then I’m going to try and follow the custom plan after I sorted it out the other day. Feeling loads better in myself following a structured plan rather then just noodling round on zwift. Will be interesting to see what, if any improvements I’ve made to ftp.
I have 3 referrals too if anybody needs one.13thfloormonkFull MemberHaving a plan is great, I spent £100 on an evening with a pro coach, he pretty much confirmed what I already knew but it felt good to know it was the right plan, could commit to it confidently.
ferralsFree Member@13thfloormonk – you mean you just had a one off session not set up with a coach long term? That sounds pretty useful.
I’m going to start base for cx in Feb. Still planning on a couple more races before then but just messing around not structured training st the moment
whitestoneFree MemberThis week’s workouts were Taylor-1, Donner & Clark.
Taylor-2: Wasn’t looking forward to this as I’d a bit of a lurgy when I woke up, maybe a reaction to something I’d eaten over the weekend. I also have felt a bit cold for the last day or so.
Anyway, needn’t have worried as I found the intervals very straightforward, there was only one (the twelfth) that I didn’t hit target power and that was because I wasn’t concentrating. On average I was around 11W higher than target power. According to the table above that means I spent twice as much time in anaerobic as threshold. I wasn’t struggling to get to the end of each interval lending more weight to my FTP being a bit low. So …
I bumped my FTP to 250W.
Donner: As a result this felt much more like a threshold workout and getting to the end of the 12 minute blocks was a bit of an effort, not digging deep sort of effort but definitely needed concentration. The last 3 minutes of the final block was definite clock watching! I wasn’t breathing particularly heavy so certainly sustainable if uncomfortable. In my current state 3x15mins at that intensity would be about my limit. If I hadn’t increased my FTP I’d have been able to go a lot longer.
So to Clark: This was a matter of finding the right gear and resistance on the trainer so that I could spin up in it and not spin out on the 200% sprints. The ones I missed were about 5% off target. The Sweet Spot intervals were about right, the first couple of minutes felt hard then gradually easier. Those below 235W felt easy overall, perhaps not surprising as 238W puts me into threshold and I’m generally aiming a Watt or two higher just to avoid slipping under the target power.
So I think I’m about spotty dog with my guesstimated FTP. Next week I’ve got Bluebell, Jepson & Palisade.
Garry_LagerFull MemberHad some fresh legs today so fancied putting a dig into the turbo – Ansel Adams+1. Quite a hard one at IF 0.98, but short and sharp intervals are better for me so I’m usually ok with it if I’m fresh. Beforehand, though, I had do a workout that would give van der Poel himself pause – 2 hours Christmas shopping at the Trafford centre!
Just not conditioned for that sort of event – out of my league. Ended up cycling there and back with the kids which was a good call, felt OK when I got back. If we’d taken the car I’d be six pints in by now. Climbed on the turbo and first 2 or 3 intervals (135% 50 sec on 40 sec off) felt like there’s NF way I’m completing this, but took a gut check and got on top of it – finished it pretty solid.
It’s odd that Ansel Adams +2 drops the recovery to 30 secs, squeezing an extra interval into each block (nine rather than eight), and yet has only a very slight increase in IF of 1.01. It sounds quite substantially harder.
steviousFull MemberSo I think I’m about spotty dog with my guesstimated FTP. Next week I’ve got Bluebell, Jepson & Palisade.
Pallisade is usually a good bellwether of your FTP estimate. I’ve given up FTP testing and just use my own judgement – the over-unders at the end of a block usually help me decide what to do with my FTP for the net block.
john_lFree MemberSerious question – why are some of you estimating your FTP rather than testing?
whitestoneFree Member@john_l – I’ve tested (using the ramp test) and subsequent workouts have felt very easy, or at least easier than they should, so I bumped my FTP. Often once you’ve done a few workouts of a particular type, say VO2Max, then you know what they should feel like so you can adjust your FTP accordingly. The TR app lets you adjust your FTP on the fly anyway, better to knock a couple of percent off and complete the workout than abandon it.
@stevious – I’ve already done Palisade this time around, it was one of the workouts in SSBLV1, here’s my notes:First full workout after my cold. I’d pushed this back from last Friday and it’s just as well that I did.
Hit just about all the power targets apart from the next to last under interval where I began to struggle a little bit. Had to dig in for the last two overs.
whitestoneFree MemberOh, meant to say. The various test protocols will suit most people but some may find that they over or under achieve on them and so need to adjust the final figure. Whether I under achieved on my last ramp test because of the test itself or some other factor or factors I don’t know but I do know that workouts that were meant to be at threshold, i.e.96%-105% of my FTP felt easy and more like Sweet Spot (88-94%) in that I was recovering slowly throughout the intervals which you shouldn’t be doing at threshold.
Also the FTP value is only relevant within the context of Trainerroad to allow you to correctly target each workout. It doesn’t really relate to outdoor riding and probably not to any other training software or program. It’s just a number.
robbo1234bikingFull MemberI did Ebbets plus one this morning. Last workout before Xmas as visiting family now for the rest of the week. Wasn’t too bad really. Did it at 6am so was fasted as well.
13thfloormonkFull Member@13thfloormonk – you mean you just had a one off session not set up with a coach long term? That sounds pretty useful.
@Ferrals – sorry I missed this, yeah it was a one off session, started with a ramp test to give me a benchmark, then some physical tests to determine flexibility/bike fit issues, then basically a sit down talking through a lot of issues and questions I had, before producing a plan based around my free time and race dates, holiday dates etc.There was nothing ground breaking, basically just a polarised 80/20 plan with some CX twists, but it gave me confidence to commit to a plan and also enough knowledge to adapt it, e.g. to make the most of a week’s holiday in Girona.
Well woryh the money, arranged via Edinburgh Bike Fitting.
13thfloormonkFull Member…although I could have done with more education about the need for strengthening as your training progresses, lack of dedicated, structured gym work and core strengthening has left me starting from square one again in the new year once I recover from lower back surgery, bye bye hard fought 3.4W/kg 🙁
Garry_LagerFull MemberAlso the FTP value is only relevant within the context of Trainerroad to allow you to correctly target each workout. It doesn’t really relate to outdoor riding and probably not to any other training software or program. It’s just a number.
I’m amazed at how powerful a number FTP is, really. As you prob know there are Brexit-level arguments online about what the real meaning of FTP is, how physiologically relevant is it, but it’s a fact that this simple parameter is sufficient for the vast majority of people to structure an effective training program around. And there’s more – you don’t even have to precisely measure the parameter! A substantially shortened test protocol is sufficient to benchmark it accurately for the majority of people.
TSS on the other hand I have no clue how that can be meaningful. A blood in the mouth 1 hr interval session is TSS 70. Go for a ride with your kids for a few hours bimbling around the bridleways – TSS 100.
13thfloormonkFull MemberGo for a ride with your kids for a few hours bimbling around the bridleways – TSS 100.
It’s so easy for a bimble to actually be zone 3 though, and a few hours at zone 3 is no small matter, would still take a day or two to properly recover from?
Garry_LagerFull MemberNah I’m talking properly taking it easy zone 1 for 2-3 hours can give you TSS 100+, at least on heart rate (my power meter is on my TT bike that I have yet to take out with the kids).
Just in general it seems to weight saddle time way more than intensity. Perhaps this is fine if you’re logging big hours training for endurance events and it does in fact give an accurate picture. But the stuff I do is cyclocross and time trialling (25 max) so it seems like it’s not that useful as a base parameter for fitness here. Particularly with respect to fatigue – one of the most valuable things TSS can give you (in principle) is a warning you’re doing too much, but it doesn’t seem to take proper account of intensity here IME.
whitestoneFree Member@Garry_Lager – I didn’t quite write what I meant!
An FTP value is only relevant to a particular bike setup in a particular environment. You’ll have a different FTP outdoors to indoors. You’ll have a different FTP on a road bike when compared to a TT bike.
That’s not to say it isn’t useful, it most definitely is! When you’ve several physiological adaptation zones spread across quite a narrow band of effort being able to zone (sic) in on the correct one is the difference between an effective training session and an ineffective one. You have to be reasonably accurate – one or two Watts either side of your True FTP isn’t going to make much of a difference but a 5% error most certainly will.
TSS does seem weird. It looks like it’s very much based on an hour’s effort so long rides skew the value. Indoor and outdoor rides seem to be on their own scales – if I log some of my ITT rides I’ll get values of 9000 or more! I’ve even had negative values but I think that’s TrainerRoad’s maths and some integer wrap-around. It’s not a parameter for fitness but workload, I can’t remember if it was in this thread or another but someone mentioned two parameters: Minimum Effective Effort and Maximum Recoverable Effort. If you use TSS as the values for those it makes more sense. So you might need to accumulate a TSS/MEE of 300 each week to see gains, if your MRE is greater than that then you can continue with that workload. If it’s lower then basically you’ll burn out.
MRE declines with age so at some point you’ll find you can’t recover from the work needed to improve so your overall performance will decline, or at least your potential maximum will decline. If you aren’t close to your potential maximum then you’ll see slow improvements for a while.
Kryton57Full MemberI’m really pleaseD to see this. In my 3rd and maybe final year of being coached, next year without a coach Trainerroad with a plan assist would be my go-to but it really needs to integrate with Zwift for longer rides / boredom relief.
<span style=”font-size: 0.8rem;”>ive very much learned recently that FTP although a measure for zones is not the be all and end all. Mine has dropped 7% since I started a bias toward endurance but I sure am fitter and faster in z2/3. I sat on Alp du Zwift yesterday up and down in Z2 happily – I’m not a climber – and steadily passing people. It was great reminder that for longer events “raising the floor” is the key metric vs “raising the roof” – although some of that will come later. For me to tap out a significant climb at constant power for an hour is a real change to my physiology and mental approach. </span>
HazeFull MemberAlmost 3 months into base and mine has steadily dropped, that’s using the modelled value from WKO4 which generally correlates well against tested efforts…have however noticed a welcome increase in Time to Exhaustion.
I base all my training on TSS, works out really well for me being time crunched, I’m targeting the right amount of time and intensity rather than racking up the hours which can be difficult.
If you need a break from TrainerRoad you can find similar workouts elsewhere which can be pushed to TrainingPeaks (needs premium) and picked up directly in Zwift. It’s good to have something different from time to time.
whitestoneFree Member@Kryton57 – “raising the floor” is a good way of putting it. While raising my FTP would be nice, it’s the sexy figure you can shout about, I’m more interested in being able to ride for ten hours at 75% of FTP rather than 70% (as an example). Of course I could raise my FTP and stay at 70% as a different way of getting there. Doing both would be even better!
However the workouts in TR (and presumably those available in Zwift) also allow you to find your weak spots so you either know what to work on when training or what to avoid when riding but probably a mixture of both. I did Jepson today and found it hard but really it’s confirmation rather than illumination on a part of my performance that I suspected anyway. Bluebell was 1 minute at 120% FTP then 1 minute recovery at 40%, repeat lots. Easy enough for me that I bumped my FTP by 2% for the last set and still found the effort OK. Jepson was 3 seconds at 150% then two minutes at just under FTP done four times per set. Really hard to recover during those two minute valleys, 90% or even 95% would have been so much more manageable.
teamslugFree MemberI’m glad I read thru the last few entries on here today. Did ramp test today after working thru SSBLV1 and was gutted that it went up all of 1 watt.!!!……but I feel loads better when I’m on the bike outside. Interesting to read about MRE and MEE above. I’m knocking on a bit now, 53 next week and have definitely noticed that I get fatigued easier than a few years ago. Not that I can’t finish the workouts but recovery is starting to take longer. My ftp is about same as last year ( tested on same turbo) but I’d be interested in your opinion. Do you think a ramp test result would be higher on a road bike than an Mtb. I’ve not been on TR for a while and whilst I realise it’s not the be all and end all I’m about 50 watts down on my peak from 3 or so years ago which was tested on a wheel on vortex with a road bike as opposed to now on an Elite Direto with an mtb?. Cheers and have a Good Christmas folks.
whitestoneFree Member@teamslug – you are on a different bike and different measurement system so I wouldn’t worry about the difference, you can only really compare like with like. No idea if you’d get a higher FTP on road or MTB, assuming same trainer, might depend on which position better suits you.
Recovery will take longer as you get older – a friend when he got to 65 said he could keep up with the club A ride on a Sunday but would then have to skip the next Sunday A ride as he hadn’t fully recovered.
Kryton57Full MemberElite Direto
An interesting coincidence but when I moved from a wheel-on turbo to my direto I swore it was harder and my ftp dropped also.
robbo1234bikingFull MemberWhat gear do you use? I have an elite Direto and use the small chain ring on the front of my gravel bike for turbo work as it resembles the MTB small chainring more. My ftp dropped about 7w when I swapped from a wheel on tacx to the elite Direto about 6 weeks ago. I think it was prob a bigger drop than that in real terms as I def had made some improvements since my last test. Think that is just the accuracy though. Don’t find the workouts particularly harder though.
Garry_LagerFull MemberRecovery will take longer as you get older – a friend when he got to 65 said he could keep up with the club A ride on a Sunday but would then have to skip the next Sunday A ride as he hadn’t fully recovered.
I watch the arl fellas cx race and some of the V60 guys are well impressive – makes you think competitive cycling is absolutely the way forward for healthy aging. But then you don’t see them laid out on the couch all week recovering from the race 🙂
steviousFull MemberSerious question – why are some of you estimating your FTP rather than testing?
I can’t face the 20 min test too often and the ramp test under-estimates for me. I’ve got enough years for TR under the belt to know what some of the workouts should feel like and I think I have enough sense to be realistic about my FTP rather than trying to aim for a big number. As others have said, its one (really useful) measure of where your fitness is but it’s not something to tie your self worth to.
