Viewing 8 posts - 1 through 8 (of 8 total)
  • Trailraker 2.1 on Flows, air leaking through sidewalls.
  • mudmonster
    Thought I’d see if my trailraker would work tubeless. It went up straight away so put in a cup of stan’s sealant. It kept slowly going down, I put soapy water around the tyre and noticed air was leaking from a few areas around the sidewall. Thought it would eventually seal but it keeps going down. Do I give up or put in more sealant? The rims are ztr flows.
    pbooker1995
    Tape or Rim Strip?
    bigyinn
    More sealant, slosh about and lay it on its side, on a bucket. Slosh the sealant around again and repeat.
    mudmonster
    Yellow rim strip. Gonna put more sealant in then. Cheers
    simondbarnes
    More sealant and then ride it – best way to get the sidewalls properly coated.
    Northwind
    Have you ridden it? Most tyres continue to fizz til they’ve had a ride IME
    mudmonster
    Not ridden it. Seems to be staying up now though. Will be riding a lot at the weekend 😀
    z1ppy
    Try lying them on the side allow to fizz/seep through & seal, turn over & repeat, then top up (opps just repeating what been said above -goes to show it decent advice 😉 )
The topic ‘Trailraker 2.1 on Flows, air leaking through sidewalls.’ is closed to new replies.
