OK first of all, I have a basic understanding of how the system works, but if there is a website that gives a detailed explanation of the inner workings that would be great…
I have a trailer than weighs 1400kg empty, 3000kg Max.
It has a hitch rated to 3500kg, so pretty heavy duty.
When I first got the trailer about 6 months ago, the hydra damper worked smoothly and the brakes were quite smooth as they came on. Also, trying to reverse without the manual reverse being engaged on the hitch was almost impossible.
Now, the trailer doesn't brake gently, the coupling sticks and then as I brake harder it lurches into the van and the brakes come on quite hard. The sticking coupling is probably just a lack of grease and can be sorted via the grease nipples. When the trailer is empty it locks up under firm braking, when loaded, it just makes for a not very smooth ride. Which can be a problem when the load is a couple of horses 😯 .
But my main concern is when reversing, I don't have to engage the manual reverse any more, the brakes just don't seem to work very well. Is this likely to be because the trailer had been standing for 12 months before we bought it so the brakes were rusted up and had a lot more friction, or is the braking mechanism likely to be at fault?
I don't mind the brakes not working in reverse as there is never a situation where you would want them to work in reverse, but seeing as the mechanism is designed to apply the brakes when the coupling compresses, I don't understand why they wouldn't?! Note it is not an auto-reverse hitch.
