Currently renovating the new house and having a full new heating system fitted (gas combi and radiators).
Had assumed I would want simple towel rail radiators in the bathrooms connected up to the central heating system (the towel rails will be the only source of heating in the bathrooms).
However, the builder pointed out that it’s not on most of the year but you really you do want the towel rails on to some degree year-round to warm/dry towels.
Good point I thought.
He recommended going for electric oil-filled ones instead. He said they are efficient these days and would heat the rooms for a similar cost to wet central heating. I was surprised to hear this, but it sounded good if true.
Had a couple of plumbers round to quote for the install and the first one went along with the builders logic.
Second one did not agree and thought they would be expensive to run. He recommended to get dual-fuel ones which are on the CH system but also have an electric element in them so can be run independently when CH not in use.
This sounds like best of both worlds, but of course is the most expensive option.
Anyone else faced the same dilemma?
Should I just go fully electric or will I regret it when I see the electricity bills?
Or should I bite the bullet and stump up the cash for the dual-fuel ones?
