If you’re going to tour with heavy loads and climb steep hills, especially on rough “roads” you can’t really have “too low” a gear. Spinning at 4kmh in a 22 chainring and 34 sprocket combination is far preferable to getting off and pushing.
That said touring doesn’t always involve heavy loads/steep hills/rough roads (or at least all three at once).
44T big ring does seem a bit low, easy to spin out on that even on the flat, and again if you’re touring with heavy loads on good roads, you’ll want to build up some momentum on the downs to tackle the next rise.
I have 26/36/48T on my expedition tourer and would recommend that if carrying big loads. For lighter touring, on decent roads, your current setup sounds like it should be fine (if it is indeed a 50/39/30 triple – if your smallest ring is 39T then I’d get it swapped!). Are you actually finding the low gear is too high, or just feeling that you “should” change?
