I’m not sure I’d enjoy it as a descent…….is it not a bit ‘picking your way down’ rather than the ‘letting it go
Heading off the Coulags side it’s loose marbley corners at the start, then a long, punishing section of fixed rock, then loose corners again at the bottom.
Steeper and more difficult than the other descents, but quite enjoyable in a masochistic way.
In the Annat direction it starts brilliant, then it’s traversey singletrack with a few stoppy sections until you rejoin the Annat descent.
GavinB – I honestly found the push-up really enjoyable, it’s a very easy gradient after the woods. Might try your suggestion next time though.
