Just resolved this problem on my on one fatty.
Problem, not enough headtube for wee ride clamp due to short headtube and top tube design.
Options , clamp to frame and damage frame, clamp to steerer tube spacers and risk scoring steerer and causing failure at some point (also loads of friction)
Solution,
Sealed Bearing race that has the internal diameter of the steerer tube (bit looser) and an outside diameter and thickness that fits in the weeride clamp. This way I replace a couple of steerer spacers with the bearing and clamp the weeride front clamp to that, voila. No friction in steering and no damage to steerer from spacers rubbing whilst turning. Bearing was a cheap one from eBay and I added some insulation tape to better seal it. Rock solid on first ride out
Well chuffed with result.
