I agree that centralising the caliper is really important on the Tech brakes, but I’d be surprised if it effected lever throw that much.
My guess is that they need a proper bleed. 3 things to watch out for, only two of which are in the Hope video on brake bleeding:
1) On the Tech caliper, the mounting and angle of bike on a stand can put the bleed valve below the lowest point of the caliper so you can get trapped air
2) The bleeding must be done with the bite point adjust screwed all the way OUT
3) You need to do the finish action of turning the reservoir through 90 deg before final fill, and roll the diapraghm on, as per the video on the website
