Similar weight to you and yes I have had problems as well although I have found a system that works more or less perfectly.
I tried running the UST system on my DH bike and just couldn't get it to work. I went through two sets of dual ply UST Maxxis High Rollers, pinch flatting both front and rear before I gave up on that system and went back to tubes.
On my trail bike the best success I've had is with Stans Flow rims and Maxxis High Roller/Minnion DHF 2.35 Singple Plys. Using a wire bead rear is essential although I can just about get away with a kevlar bead front. This set up works 98%.
Using Specialized Roval Traverse wheels, I can't run them tubeless on the rear with any tyre; the load in corners of the side wall is too great and I end up blowing the tyre off the rim, even with wire bead High Rollers. The front I can run tubeless with a Kevlar bead tyre.
What I've learnt from this is that tubeless success depends on a number of factors including weight, riding style, tyre pressure and tyre/rim combo. The heavier you are and the more aggressive you ride in the corners, the harder it's going to be to get working. You need a stronger side wall and wire beads to give the tyre the support it needs to prevent burping.
