Viewing 10 posts - 1 through 10 (of 10 total)
  • Todays Excel Tester….. Dates…..
  • harrytoo
    Morning Team, just a quick excel tester this morning….
    I am putting together a sheet relating to bookings and programming when certain things associated with said booking need to be done….
    Column D Can either be blank / empty or have a date in if booked.
    Column I needs to replicate that date (or have an empty / blank cell if no date in Column D)
    Column G will need the cell in Column I less 7 days (if it contains a date) or return a blank if no date is yet entered in Column D.
    Obviously its easy enough to do using the If function, however as everything is done in date format a blank cell defaults to 01-Jan-1900.
    I have tried different Date formats but I cannot get a zero / blank cell to return where I need it.
    Solution required please…….
    gobuchul
    Conditional formatting?
    Set to change format to number when zero?
    Just a guess, not sure if it’s possible.
    njee20
    In column I: =if(d1<>0,d1,””)
    In column G: =iferror(i1-7,””)
    stumpy01
    ^^^what he said…
    dangeourbrain
    =if(i1=0,””,i1-7)
    Only obviously d not i
    harrytoo
    All working using the rather nifty “iferror” function.
    Reward yourselves with a nice cup of tea, maybe a biscuit.
    njee20
    Thanks, maybe I will!
    Now… why isn’t this doing what I want?
    =IF(BE33>1,0,-IF(D34>0,MAX(A34,0),0)+IF(AND(IFERROR(VLOOKUP(C34-$V$18,$Z$10:$AF$15,1,0),0)=C34-$V$18,BE33=1)=TRUE,-MAX(A34,0),0))
    Sundayjumper
    I think this should do it, custom number format:
    dd-mmm-yy;;
    I think the main problem you’ve run into is that Excel can’t format a negative date, so you end up with ######### instead. It’s not strictly an error. The formatting above will simply hide it.
    dangeourbrain
    njee20 – Member
    Because that’s no way to program a Bluetooth kettle, obviously
    Also you seem to have an extra clause in your vlookup from what i can read, and you look to be returning column 1 in the range, which seems odd.
    njee20
    I was kidding really, it does actually work, although wasn’t my formula, I’m sure it can be cleaned up!
The topic ‘Todays Excel Tester….. Dates…..’ is closed to new replies.
