Viewing 30 posts - 1 through 30 (of 30 total)
  • to the male runners out there…
  • jon1973
    Been doing a fair bit of running lately, working towards a half marathon early next year. Have started to suffer in the nipple department. Any more than about the 3 miles and it seem to be a problem, not so much on the run itself, but aterwards.
    Any advice?
    joshvegas
    Slap on the vaseline.
    or a compression top that stops your moobs jiggling.
    Jamie
    Plasters.
    joshvegas
    Plasters are fine unless you have a hairy chest
    jon1973
    I may give vasaline a go. I have a ring of hair around each nipple, so plaser removal couple be painful.
    chip
    Get some body glide and get some running specific tops, does not have to be tight fitting just not cotton as cotton chaffs .
    Only the once.
    scruff9252
    Or micropore tape may be more cost effective. Also be a bit more selective with your tops. I have a couple where no issue at all (decathlon own brand) but one I got from the Alloa half, may as well be made from a cheese grater!
    jonjones262
    I bought a roll of cheap medical tape off ebay. You cut a tiny square to cover your teat. Doesn’t get caught in your hairs then.
    chambord
    I think he’s dissing your manliness Jamie
    joshvegas
    technical tops can be pretty bad too.
    its not the removing of the plasters its the tugging of the hairs as you your chest exoands and contracts/jiggles
    Duggan
    I find wearing two layers helps, like a baselayer and t-shirt over the top. Not so good in summer though.
    chip
    I found body glide a must, never had problems with my nipples but used to run 7 miles every other day and if I forgot to use body glide my todger would look and feel like it had serious sun burn.
    paulosoxo
    Vaseline, or a base layer. I like the ventilated types, like the one from DHB, below. Saying that, I only ever really get joggers-nip when it’s raining..
    http://www.wiggle.co.uk/dhb-lite-fit-short-sleeve-base-layer/
    teamhurtmore
    Micropore +1
    mark90
    Sports bra?
    Jamie
    sofatester
    Go topless and show off your hairy chested manliness?
    Lucas
    Roll of medical paper tape from the pound shop, take off in shower afterwards. I have a manly hairy chest get sore nips and this works for me
    banjax34
    stayed on for tough mudder! http://www.runguards.com/products/nipguards
    back2basics
    sand them off
    Ro5ey
    Try a different make of top.
    I prefer Nike and puma…. Adidas or NB irritate me
    brooess
    Too much info 😯 this isn’t Mumsnet!
    spud-face
    just cut strategic circles out of your t-shirts
    joshvegas
    chambord – Member
    POSTED 45 MINUTES AGO #
    Sorry Jamie, I’m sure you are a fine figure of a man.
    Jamie
    Wait….so no-one else waxes their nipples?
    jon1973
    Too much info this isn’t Mumsnet
    YABU
    Nipple hair is nothing to be ashamed of.
    maccruiskeen
    We don’t need to. Not since you told us to stick plasters on them, which we all went off and dutifully did, so theres nothing left there to wax now. Its as if million stwers cried out in terror and were suddenly silenced.
    johnj2000
    Skins type base layer or lots of vas does the trick. Benefit of the base layer is that it holds the wobbly bits in as well.
    antigee
    Ro5ey – Member
    gets my vote – I wondered what all the fuss was about for years and years and years (pretty old) then one day it happened on quite a short run too …. wow pain big time
The topic ‘to the male runners out there…’ is closed to new replies.
