josh & tang +1, get a local experienced sweep in there & ask them their opinion, worth getting the chimney swept before fitting a liner anyway & should only be a few quid.Three reasons to get a chimney lined, one if ya chimneys knackered, two if its way bigger than it needs to be & might cause problems with draw on a wood stove, three if there are ledges or other soot traps that would help start a chimney fire.
Rockhopper – nearly there, compared with a stove an open fire needs a far greater volume of air to be pulled up the chimney to help ensure that smoke doesn’t blow back into the room, so they need a larger cross section of chimney to achieve that & this results in much more heat being lost up the chimney too
