Fantastic – had mine now for about 16 months and its been faultless. Only had to replace the rear bushes last week as the drive side had a little squeek but it only took about 20mins to do.
Theres a previous thread here about the FTM:
FTM Link
I run mine as a 2×9 and fitted a K-Edge chain catcher after the first ride as if the chain does jump of the inside it can catch between the frame. Alternatively running it 1×10 is quite appealing plus you can then use the internal cable routing for the front mech to feed your dropper post cable.
I only helitaped inside the chainstay and around the bottom bracket area, the underside is very well protected with a shield and the frame finish is very durable.
I dont think you can find a better frame for the money. It will take a couple of weeks for the bushes on a new frame to wear in but after that the suspension is smooth as. I would recommend if you can afford it a two stage or adjustable fork. With a 140mm fork up front it can feel a little wandery/lifty up really steep climbs, but with a Talas 110/140 it climbs great and eats descents. Of course if your riding doesnt include steep climbs it doesn’t matter.
My recommendation would be buy one – you wont regret it.
