Viewing 14 posts - 1 through 14 (of 14 total)
  • Titanium bolts
  • PaulBecks
    Is it safe to replace full sus pivots and linkages with Ti ones? If so, does anyone know who can supply? I can get everythnig else on the bike but have struggled when trying to find larger threads and patterns.
    GNARGNAR
    Place on ebay, I think they’re just called ti bolts?? I personally wouldnt put any near pivots.
    snaps
    I see no problem replacing them if you check the torsional properties are the same or better than what you’re replacing.
    Ti bolts is Superstar components.
    http://www.tastynuts.com/ is where I get mine from.
    KINGTUT
    I ordered some Ti Bolts from Superstar, the first ones I received were OK (caliper bolts), I then ordered some disc bolts and a Hope Mini lever kit, the quality was appalling, sent the lot back and got a refund.
    nickc
    Should be OK, as long as they’re from a decent source.
    Offroading
    Superstar ones are poor IMO – i’ve had some with cracked heads, unpolished so all the machine grooves are still present etc.
    clubber
    suspension pivot bolts shouldn’t be under heavy load if it’s a decent frame design so it should be fine for most bikes. I wouldn’t be willing to pay but if i was given them i’d have no problem using them.
    clubber
    slight caveat to that. I wouldn’t use ti bolts for the shock as they’re directly loaded.
    TrailriderJim
    TI Bolts ones I’ve used for my stem are soft as sh*t. They just round off on the allen keys.
    gonetothehills
    Yeah – mine did too. Never had it happen from other suppliers. Really poor show all round. And the disc brake mounts were too long – well they were for all the frames I tried them on. Hey ho. Nothing ventured etc.
    XC_PK
    TJ & GTTH- Thanks I was going to order some bolts from Ti Bolts but will use one of the other companies.
    PB- Replied to your mail
    Offroading
    Some frames use alloy bolts – so i think its safe to say Ti is fine…
    njee20
    I was gonna say, most frames use alu bolts if they’re a big size, Spesh and Trek definitely do.
    It’ll be fine, there’s nowhere on a bike I wouldn’t use ti bolts.
    As for a supplier, try Pro Bolt
    uplink
    I prefer to use stainless steel bolts
    I’d have no technical worries with Ti but I only want corrosion resistance & aren’t bothered about a couple of grams in weight
    Stagonset
The topic ‘Titanium bolts’ is closed to new replies.
