Just finished building it finally...
Hey Simon I bought one of those On One prototypes for my wife. It was a bargain and is still much admired.
BTW if anyone wants to buy a nice medium Ti hardtail frame for £300 + P&P then email for pics and spec.
456Ti
Gruenermoench - what are the bars on your bike?
IF
They are Ti Luv Handles from Groovy Cycles.
Gruenermoench ,what bikes attached to your luv handles ? looks lush
I took delivery of it just a few weeks ago. It was built by Scott Quiring in the US and is based on a Ventana rear end that I bought second hand on here.
ade ward
Could you explain your bike?
i wanted a very short chainstay 29er with loads of mud clearance
chainstays 417mm to 437mm and at least 10mm between a 2.5 tyre and any part of the frame,
dropouts clamp with three bolts giving a more stable platform than a 2 bolt slider,, it only changes ride height by 2mm at over the 20mm movement ,
I really like that Ade Ward... loving the 'slammed' stem and the e-stay, plus those dropouts look totally industrial and cool!
Lynskey Ridgeline 29 Rohloff at about 6 months old.
Picture 018 by Vegan Graham, on Flickr
And again at 11 months old.
ANOTHER cracked Lynskey. It looks like they didn't even fusion weld a collar into the seattube.
Did they warranty it?
Graham those are pretty nasty looking cracks! What was the out come? What was the cause? Did they sort a replacement ok?
BTW the Brodie from Si looks just right! reminds me of when I first saw the slightly curved top tube on the Lynskey 456. Somethings just look right.
MidlandTrailquestsGraham - My Lynskey built Hummer went in exactly the same way
I'm going to try and get it boxed up and posted back to CRC tomorrow, although it might be Monday now.
I'd prefer a refund if I can. I don't expect CRC will do that, so I'm hoping for a replacement rather than a repair.
The walls of the seattube are too thin to cope with the forces caused by the the seatpost which is why the area should be reinforced with a collar / insert which is usually fusion welded in place.
http://www.paragonmachineworks.com/cgi-bin/commerce.cgi?search=action&category=SC09
You can just see the weld beading in the below pic.
You must log in to post.
