Stage 19 – Albertville / Saint-Gervais Mont Blanc – we are staying near the finish.
Want to get a good spot to park my camper on a climb BUT not to the point where we kip out on a mountain overnight OR have to walk/cycle a while. I was thinking to avoid the finish and instead drive up towards the top of the days big climb Montée de Bisanne which is 50k from the finish. The caravan is supposed to get there about 14:00.
If we got there about 10:00 how likely will we be able to park up somewhere good to get pre-loaded with wine and cheese?
Some good info generally and stage specific here. As others have said, if you want to get a camper up, you really need to be going up day before, not least because there won’t be any spaces left if you don’t. For many of the major climbs the road will close the day before, though not clear if the Bisanne is one of those but many of the roads around stage 19 seem to start closing at 5am.
Best tip is to have a sister in law who happens to own a place in St Gervais right on the tdf route! I couldn’t believe it when I found out so I’m flying over to Geneva this Weds for a couple of weeks.
@igm nauchetts runs in the summer, top of the bike park (note if you look at IGN maps the ski lifts marked in purple are the ones which normally run in the summer). Ranfouilly doesn’t run – I can also tell you its not worth the climb up the gravel track to the arrete as its not ridable down 😳
OP as above you’d have to be on the climb 1-2 days before. If you have bikes park in Les Gets and either ride up or take the lifts then ride round to Lac Joux Plane and down a bit. Take backpacks full of food, beverages and sun screen. just seen you are in St-Gervais but similar rules apply, maybe there is a cheeky route on mtb’s down from Les Houches lift
